- 4Controll
- 4ETS - 4 Electronic Traction System
- 4Matic
- 4Mmotion
- 4WAS
- 4WS - 4 Wheel Steering
- A B-H A - Adaptive High-Beam Assistant
- AA - Attention Assist
- AAS - Adaptive air suspension
- AB - Adaptive Brake
- ABA - Active Brake Assist
- ABC - Active Body Control
- ABD - Automatic Brake Differential
- ABS - Antilock Braking System
- ACC - Adaptive Cruise Control
- ACD - Active Center Differential
- ACE - Active Cornering Enhancement
- Active Steering BMW
- AD - Active Drive - 4Control
- Adaptive 4x4
- Adaptive ESP
- Adaptive light, luci adattive
- ADIM - Active Drive Integrated Management
- ADR
- ADS - Adaptive Damping System
- ADS - Audi Drive Select
- AE
- AFE - Assistenza alla Frenata di Emergenza
- AFL - Adaptive Front Lighting
- AFS - Active Front Steering
- AFS - Adaptive Front lighting Systems - AFSL - AFL
- AFU - sistema di aiuto alla frenata di emergenza
- AGS - Adaptive Gearbox Shift
- AHBS - Active Handling Brake System
- AHK - Active Hinterakskinematic
- Airbag a tendina - Window bag
- Airbag Europeo - Eurobag
- AIRMATIC DC - Dual Control
- AKS - Poggiatesta attivi Volkswagen
- ALA (Audi Lane Assist)
- ALB - Anti Lock Braking
- ALC - Adaptive Light Control
- Alcokey
- Ammoritzzatori a controllo elettronico
- Ammortizzatori pneumatici
- AMR - Audi Magnetic Ride
- AMVAR
- ANCS - Active Noise Control System
- Anti-lock
- Anti-skid
- Anti-spin
- Antisbandamento
- ARS - Active Rear Steering
- ART - Abstandsregel-Tempomat
- ASA - Audi side assist
- ASB - Active Sensor Bearing
- ASB - Active Steering BMW
- ASBS - Active stabilizer bar system
- ASC - Automatic Stability Control
- ASC+T - Automatic Stability Control and Traction control
- ASD - Automatisches Sperrdifferential
- ASF - Audi Space Frame
- ASL - Avviso Superamento Linea
- ASR - Acceleration Slip Regulation
- AWC - All Wheel Control e S-AWC - Super All Wheel Control
- AWD - All Wheel Drive
- AWR - Abastandswarnradar
- AYC - Active Yaw Control
- BAS - Brake Assistant System
- BDC - Brake Dynamic Control
- BDW - Brake Disc Wiping
- BER - Blue Eyes Radar
- Bilstein DampTronic
- BKV
- Blinker
- Brake by wire
- BSD - Blind Spot Detection
- BSIS - Blind Spot Information System
- BSM - Blind Spot Monitor Monitor punti ciechi
- BUS
- By-wire
- C.A.T.S. - Sistema computerizzato di controllo attivo delle sospensioni
- Cambio adattivo - AGS - DSP - Dinamishes Schaltprogramm
- Cambio sequenziale automatico
- CBC - Cornering Break Control o CBS - Cornering Break System
- CBS
- CDC - Continuous Damping Control
- CDS - Controllo dinamico della stabilità
- Cintura di sicurezza
- City safety
- CMBS - Collision Mitigation Brake System
- COF
- Concetti Generali
- CSC - Cornering Stability Control
- CWAB - Collision Warning with Auto Brake
- CWBS - Collision Warning with Brake Support
- CyberWheel e CyberTyre
- DA - Distance Alert
- DAC - Downhill Assist Control
- DAS - Driver Attention System
- DAS - Driver's Assistance System
- DASS - Driver Attention Support System
- DAWS - Driver Attention Warning System
- DBC - Dynamic Brake Control
- DCAS - Distance Control Assist System - DCA
- DCC - Dynamic Chassis Control
- DCCD - Drivers Control Center Differential
- DD
- DDC - Driving Dynamic Control
- Differenziale attivo
- Differenziale autobloccante
- Differenziale epicicloidale
- Differenziale ripartitore
- Differenziale torsen
- Dischi freno in ceramica
- Distronic
- Distronic plus
- DRC - Dynamic Ride Control
- DRC - Dynamic Rolling Control
- Drive by wire - EGas - ETCS - Acceleratore elettronico - EFP
- DSA - DSAC - Dynamic Stering Angle Control
- DSC - Dinamic Stabilty Control
- DSG - Direct Shift Gearbox
- DSR - Downhill Speed Regulation
- DST - Dynamic Steering Torque
- DSTC - Dynamic Stability and Traction Control
- DTC - Dynamic Traction Control
- Dynamic drive - DD
- E-Diff
- EBA - Electronic Brake-power Assist
- EBAC - Engine Brake Assist Control
- EBD - Electronic Brake Distribution
- EBP Electronic Brake Prefill
- EBV - Electronic Brake Variator
- ECS - Early Crash Sensor - Sensori early crash
- ECS - Electronically Controlled Suspension
- ECT - Electronic Controlled Transmission
- EDC - EDC-K
- EDL - Electronic Differential Lock
- EDS
- EFP
- EGas
- EHB - Elektro Hydraulische Bremse
- EMS
- EMS - Electronic Motor System
- ENR - Elektr. Niveauregelung
- EPS - Electronic Power Steering
- ERM Electronic Rollover Mitigation)
- ESC - Electronic Stability Control (ESP - Electronic Stability Program)
- ESC 2.0
- ESP Plus
- ESP premium
- ESP/4ETS
- ESS - Electronic Suspension System
- ESS - Emergency Stop signal System
- ETC - Electronic Traction Control
- ETCS - Electronic Throttle Control System
- ETS - Electronic Traction System
- EVA - Emergency Valve Assist
- F1-TRAC
- Fari allo xeno
- Fari statici autosterzanti
- FCS - Front Camera System
- FCW - Forward Collision Warning
- FDR - Fahr-Dynamik-Regelung
- FIR - Far Infra Red
- FOUR-C - telaio ad assetto attivo
- FRIZIONE HALDEX
- FSR - Full Speed Range
- GRC - Gradient Release Control
- HAC - Hill start Assist Control
- HALDEX
- HBA - Hydraulischer Brems Assistent - BAS - Brake Assistant System
- HBV
- HDC - Hill Descent Control
- HFC - Hydraulic Fade Compensation
- HHC - Hill Hold Control
- HICAS - High Capacity Actively-controlled Suspension - Super HICAS
- HILL ASSIST
- HLA
- HPS - High Pressure Support
- HSA - Hill Start Assist
- HUD - Head Up Display
- I sistemi in generale di sicurezza attiva
- IAS - Integral Active Sterling
- IBA - Intelligent Brake Assist
- ICC - Intelligent Cruise Control
- IDS - Interactive Driving System
- IDSPlus - Interactive Driving System
- INVECS-II - Intelligent & Innovative Vehicles Electronic Control System
- ISOFIX - Attacco seggiolini bimbi
- IVDC
- LANE ASSIST
- LCS
- LDP - Lane Departure Prevention
- LDW - Lane Departure Warning - LDWS
- LKA - Lane Keeping Assist - LKAS - Lane Keeping Assist System
- LRR - Long Range Radar
- LSD - Limited Slip Differential
- LSS - Lane Support System
- MASC / MATC (Mitsubishi Active Stability Control - Mitsubishi Active Traction Control
- MBA - Mechanical Brake Assist
- MCF - Mu-Split control function
- Monitori di assistenza negli incroci
- MRC - Magnetic Ride Control
- MSP - Maserati Stability Program
- MSR
- MSR - Motor Schlepp Regelung
- NBA - Nissan Brake Assist
- NIGHT VIEW - Vista notturna o NVA - Night View Assist
- NIGHT VISION - Visione Notturna
- NIR - Near Infra Red - Infrarossi per la vicinanza
- NVA - Night View Assist
- Opel eye
- PASM - Porsche Active Suspension Management
- PAX - Pneumatici PAX system
- PBC
- PCCB - Porsche Ceramic Composite Brake
- PDCC - Porsche Dynamic Chassis Control
- PDK - Porsche Doppelkupplung
- Pedaliera collassabile - PRS
- PLM - Sterzo parametrico
- PML - Parameterlenkung
- PRE-ASR
- PRE-CRASH by Toyota
- Pretensionatore cintura di sicurezza
- Privo 2
- PSM - Porsche Stability Management
- PTM - Performance Traction Management
- PTM - Porsche Traction Management
- Q2 - Electronic Q2
- Q4
- Quattro
- RA - Agente Robotico
- RAS - Rear Active Steering
- RDC - Reifen Druck Control
- RDC - Roll Stability Control
- RDK - Reifen Druck Kontrol
- ReAxs
- REF - Ripartitore elettronico di frenata
- RSC - Roll Stability Control
- RSS - Road Sensing Suspension
- Run Flat pneumatici
- SBC - Sensotronic Brake Control
- SBW - Steer-by-Wire
- SC - Stability Control
- SCM - Sospensioni a Controllo Magnetoreologico
- SCS
- SDC - Synamptic Damping Control
- SERVOTRONIC
- SH-AWD - Super Handling - All Wheel Drive
- SIDE ASSIST - Visione nell' angolo cieco
- SKYHOOKS
- Sospensioni pneumatiche
- SPA - Spurassisten
- Spees limit
- SPLIT
- SRR - Short Range Radar
- SRS - Supplemental Restraint System - Sistema di Ritenuta Supplementare
- SSPP
- SSPS - Speed Sensitive Power Steering
- StabiliTrak
- STC - Stability and Traction Control
- STEPTRONIC
- T.W.I. - Tread Wear Indicator
- Targa auto illuminata
- TCP - Traction Control Program
- TCS - Traction Control System
- Telecamera a 360 gradi
- Terrain response
- TIPTRONIC
- TMC - Traffic Message Channel
- TPM - TPMS - Tire Pressure Monitoring System
- TPS - Trailer Stability Program
- TRAC DSC
- TRACS
- Traction4
- TRC
- TSA - Trailer Stability Assist
- TSR - Traffic Sign Recognition
- TTD - Transfer Traction Differential
- TWIN DIFF
- ULC - Understeer Control Logic
- VDC - Vehicle Dynamic Control - VDCS - Vehicle Dynamic Control System
- VDIM
- VDR-R - Vehicle Dynamic Control
- VSA - Vehicle Stability Assist
- VSC - Vehicle Stability Control
- WRG - Water Repellent Glass
- XDrive
- XWD
Questi tipi di attacco si trovano di serie su quasi tutti i modelli di vetture.
Tali attacchi permettono un migliore ancoraggio del seggiolino alla vettura poiché gli stessi attacchi sono di norma saldati direttamente al telaio della vettura.
Il 26 febbraio 2004 è entrato in vigore un nuovo supplemento nell'ambito della ECE R44/03, normativa di riferimento per la produzione e la commercializzazione dei sistemi di ritenuta per bambini durante il trasporto in auto.
La nuova norma regolamenta a livello europeo il sistema ISOFIX, un dispositivo innovativo che offre una soluzione specifica: un sistema d'aggancio che interfaccia direttamente il seggiolino e il sedile dell'auto, senza l'utilizzo delle cinture di sicurezza in dotazione all'auto, destinate agli adulti.
Il seggiolino in questo caso diventa un tutt'uno con il sedile dell'auto, offrendo una serie di benefici, tra i quali una maggiore sicurezza, una notevole praticità d'installazione e la certezza della corretta installazione.
La norma stabilisce che, dal 2006-2007, tutti i nuovi modelli di automobili dovranno disporre di agganci ISOFIX per due dispositivi di ritenuta (successivamente l'obbligo si estenderà a tutte le vetture di nuova fabbricazione immesse sul mercato) oltre a questo fissa precisi parametri di produzione ai quali si devono attenere sia i costruttori di automobili sia i produttori di seggiolini auto.
Pur in mancanza di una normativa specifica, negli ultimi anni alcune case automobilistiche hanno già iniziato ad inserire gli agganci ISOFIX nei modelli più recenti delle proprie vetture, come dotazione di serie o come accessorio opzionale.
Ulteriori informazioni utili in questo sito
LEGGERE L'ETICHETTA
A) Normativa di riferimento
B) Questa scritta si riferisce alla compatibilità del seggiolino con qualsiasi automobile (universal)
C) Peso autorizzato del bambino
D) Codice internazionale, indica il Paese che ha rilasciato l'omologazione (es.E2/Francia,E3/Italia, E4/Olanda)
E) Numero di omologazione
I GRUPPI ISOFIX
L'elemento fondamentale che regola la scelta di un seggiolino auto è il peso delbambino.
Secondo la normativa europea i diversi pesi dei bambini sono statisuddivisi in Gruppi di Massa (vedi la tabella).
