Home > Sistemi di sicurezza attivi e passivi > Anti-lock
Glossario sistemi di sicurezza, passa con il mouse sopra le lettere
- 4Controll
- 4ETS - 4 Electronic Traction System
- 4Matic
- 4Mmotion
- 4WAS
- 4WS - 4 Wheel Steering
- A B-H A - Adaptive High-Beam Assistant
- AA - Attention Assist
- AAS - Adaptive air suspension
- AB - Adaptive Brake
- ABA - Active Brake Assist
- ABC - Active Body Control
- ABD - Automatic Brake Differential
- ABS - Antilock Braking System
- ACC - Adaptive Cruise Control
- ACD - Active Center Differential
- ACE - Active Cornering Enhancement
- Active Steering BMW
- AD - Active Drive - 4Control
- Adaptive 4x4
- Adaptive ESP
- Adaptive light, luci adattive
- ADIM - Active Drive Integrated Management
- ADR
- ADS - Adaptive Damping System
- ADS - Audi Drive Select
- AE
- AFE - Assistenza alla Frenata di Emergenza
- AFL - Adaptive Front Lighting
- AFS - Active Front Steering
- AFS - Adaptive Front lighting Systems - AFSL - AFL
- AFU - sistema di aiuto alla frenata di emergenza
- AGS - Adaptive Gearbox Shift
- AHBS - Active Handling Brake System
- AHK - Active Hinterakskinematic
- Airbag a tendina - Window bag
- Airbag Europeo - Eurobag
- AIRMATIC DC - Dual Control
- AKS - Poggiatesta attivi Volkswagen
- ALA (Audi Lane Assist)
- ALB - Anti Lock Braking
- ALC - Adaptive Light Control
- Alcokey
- Ammoritzzatori a controllo elettronico
- Ammortizzatori pneumatici
- AMR - Audi Magnetic Ride
- AMVAR
- ANCS - Active Noise Control System
- Anti-lock
- Anti-skid
- Anti-spin
- Antisbandamento
- ARS - Active Rear Steering
- ART - Abstandsregel-Tempomat
- ASA - Audi side assist
- ASB - Active Sensor Bearing
- ASB - Active Steering BMW
- ASBS - Active stabilizer bar system
- ASC - Automatic Stability Control
- ASC+T - Automatic Stability Control and Traction control
- ASD - Automatisches Sperrdifferential
- ASF - Audi Space Frame
- ASL - Avviso Superamento Linea
- ASR - Acceleration Slip Regulation
- AWC - All Wheel Control e S-AWC - Super All Wheel Control
- AWD - All Wheel Drive
- AWR - Abastandswarnradar
- AYC - Active Yaw Control
- BAS - Brake Assistant System
- BDC - Brake Dynamic Control
- BDW - Brake Disc Wiping
- BER - Blue Eyes Radar
- Bilstein DampTronic
- BKV
- Blinker
- Brake by wire
- BSD - Blind Spot Detection
- BSIS - Blind Spot Information System
- BSM - Blind Spot Monitor – Monitor punti ciechi
- BUS
- By-wire
- C.A.T.S. - Sistema computerizzato di controllo attivo delle sospensioni
- Cambio adattivo - AGS - DSP - Dinamishes Schaltprogramm
- Cambio sequenziale automatico
- CBC - Cornering Break Control o CBS - Cornering Break System
- CBS
- CDC - Continuous Damping Control
- CDS - Controllo dinamico della stabilitÃ
- Cintura di sicurezza
- City safety
- CMBS - Collision Mitigation Brake System
- COF
- Concetti Generali
- CSC - Cornering Stability Control
- CWAB - Collision Warning with Auto Brake
- CWBS - Collision Warning with Brake Support
- CyberWheel e CyberTyre
- DA - Distance Alert
- DAC - Downhill Assist Control
- DAS - Driver Attention System
- DAS - Driver's Assistance System
- DASS - Driver Attention Support System
- DAWS - Driver Attention Warning System
- DBC - Dynamic Brake Control
- DCAS - Distance Control Assist System - DCA
- DCC - Dynamic Chassis Control
- DCCD - Drivers Control Center Differential
- DD
- DDC - Driving Dynamic Control
- Differenziale attivo
- Differenziale autobloccante
- Differenziale epicicloidale
- Differenziale ripartitore
- Differenziale torsen
- Dischi freno in ceramica
- Distronic
- Distronic plus
- DRC - Dynamic Ride Control
- DRC - Dynamic Rolling Control
- Drive by wire - EGas - ETCS - Acceleratore elettronico - EFP
- DSA - DSAC - Dynamic Stering Angle Control
- DSC - Dinamic Stabilty Control
- DSG - Direct Shift Gearbox
- DSR - Downhill Speed Regulation
- DST - Dynamic Steering Torque
- DSTC - Dynamic Stability and Traction Control
- DTC - Dynamic Traction Control
- Dynamic drive - DD
- E-Diff
- EBA - Electronic Brake-power Assist
- EBAC - Engine Brake Assist Control
- EBD - Electronic Brake Distribution
- EBP Electronic Brake Prefill
- EBV - Electronic Brake Variator
- ECS - Early Crash Sensor - Sensori early crash
- ECS - Electronically Controlled Suspension
- ECT - Electronic Controlled Transmission
- EDC - EDC-K
- EDL - Electronic Differential Lock
- EDS
- EFP
- EGas
- EHB - Elektro Hydraulische Bremse
- EMS
- EMS - Electronic Motor System
- ENR - Elektr. Niveauregelung
- EPS - Electronic Power Steering
- ERM Electronic Rollover Mitigation)
- ESC - Electronic Stability Control (ESP - Electronic Stability Program)
- ESC 2.0
- ESP Plus
- ESP premium
- ESP/4ETS
- ESS - Electronic Suspension System
- ESS - Emergency Stop signal System
- ETC - Electronic Traction Control
- ETCS - Electronic Throttle Control System
- ETS - Electronic Traction System
- EVA - Emergency Valve Assist
- F1-TRAC
- Fari allo xeno
- Fari statici autosterzanti
- FCS - Front Camera System
- FCW - Forward Collision Warning
- FDR - Fahr-Dynamik-Regelung
- FIR - Far Infra Red
- FOUR-C - telaio ad assetto attivo
- FRIZIONE HALDEX
- FSR - Full Speed Range
- GRC - Gradient Release Control
- HAC - Hill start Assist Control
- HALDEX
- HBA - Hydraulischer Brems Assistent - BAS - Brake Assistant System
- HBV
- HDC - Hill Descent Control
- HFC - Hydraulic Fade Compensation
- HHC - Hill Hold Control
- HICAS - High Capacity Actively-controlled Suspension - Super HICAS
- HILL ASSIST
- HLA
- HPS - High Pressure Support
- HSA - Hill Start Assist
- HUD - Head Up Display
- I sistemi in generale di sicurezza attiva
- IAS - Integral Active Sterling
- IBA - Intelligent Brake Assist
- ICC - Intelligent Cruise Control
- IDS - Interactive Driving System
- IDSPlus - Interactive Driving System
- INVECS-II - Intelligent & Innovative Vehicles Electronic Control System
- ISOFIX - Attacco seggiolini bimbi
- IVDC
- LANE ASSIST
- LCS
- LDP - Lane Departure Prevention
- LDW - Lane Departure Warning - LDWS
- LKA - Lane Keeping Assist - LKAS - Lane Keeping Assist System
- LRR - Long Range Radar
- LSD - Limited Slip Differential
- LSS - Lane Support System
- MASC / MATC (Mitsubishi Active Stability Control - Mitsubishi Active Traction Control
- MBA - Mechanical Brake Assist
- MCF - Mu-Split control function
- Monitori di assistenza negli incroci
- MRC - Magnetic Ride Control
- MSP - Maserati Stability Program
- MSR
- MSR - Motor Schlepp Regelung
- NBA - Nissan Brake Assist
- NIGHT VIEW - Vista notturna o NVA - Night View Assist
- NIGHT VISION - Visione Notturna
- NIR - Near Infra Red - Infrarossi per la vicinanza
- NVA - Night View Assist
- Opel eye
- PASM - Porsche Active Suspension Management
- PAX - Pneumatici PAX system
- PBC
- PCCB - Porsche Ceramic Composite Brake
- PDCC - Porsche Dynamic Chassis Control
- PDK - Porsche Doppelkupplung
- Pedaliera collassabile - PRS
- PLM - Sterzo parametrico
- PML - Parameterlenkung
- PRE-ASR
- PRE-CRASH by Toyota
- Pretensionatore cintura di sicurezza
- Privo 2
- PSM - Porsche Stability Management
- PTM - Performance Traction Management
- PTM - Porsche Traction Management
- Q2 - Electronic Q2
- Q4
- Quattro
- RA - Agente Robotico
- RAS - Rear Active Steering
- RDC - Reifen Druck Control
- RDC - Roll Stability Control
- RDK - Reifen Druck Kontrol
- ReAxs
- REF - Ripartitore elettronico di frenata
- RSC - Roll Stability Control
- RSS - Road Sensing Suspension
- Run Flat pneumatici
- SBC - Sensotronic Brake Control
- SBW - Steer-by-Wire
- SC - Stability Control
- SCM - Sospensioni a Controllo Magnetoreologico
- SCS
- SDC - Synamptic Damping Control
- SERVOTRONIC
- SH-AWD - Super Handling - All Wheel Drive
- SIDE ASSIST - Visione nell' “angolo cieco”
- SKYHOOKS
- Sospensioni pneumatiche
- SPA - Spurassisten
- Spees limit
- SPLIT
- SRR - Short Range Radar
- SRS - Supplemental Restraint System - Sistema di Ritenuta Supplementare
- SSPP
- SSPS - Speed Sensitive Power Steering
- StabiliTrak
- STC - Stability and Traction Control
- STEPTRONIC
- T.W.I. - Tread Wear Indicator
- Targa auto illuminata
- TCP - Traction Control Program
- TCS - Traction Control System
- Telecamera a 360 gradi
- Terrain response
- TIPTRONIC
- TMC - Traffic Message Channel
- TPM - TPMS - Tire Pressure Monitoring System
- TPS - Trailer Stability Program
- TRAC DSC
- TRACS
- Traction4
- TRC
- TSA - Trailer Stability Assist
- TSR - Traffic Sign Recognition
- TTD - Transfer Traction Differential
- TWIN DIFF
- ULC - Understeer Control Logic
- VDC - Vehicle Dynamic Control - VDCS - Vehicle Dynamic Control System
- VDIM
- VDR-R - Vehicle Dynamic Control
- VSA - Vehicle Stability Assist
- VSC - Vehicle Stability Control
- WRG - Water Repellent Glass
- XDrive
- XWD
Anti-lock
Termine inglese: Anti chiusura, Anti blocco, sinonimo di Anti-blockier. Vedi: antibloccaggio, ABS ecc.
I sistemi qui recensiti sono stati curati dalla Redazione e dal Per. Ind. Marco Ambrogiani di Genova. Pertanto tutte le schede tecniche sono sottoposte a Copyright
Ultime news
Esodo estivo e incidenti stradali: necessario un cambiamento di rotta
Salerno - Sicurezza stradale, Iannone "educazione giocosa dei giovani"
Incidenti stradali - Ricerca: prima causa è mancato rispetto precedenza
Codice stradale, Brescia col pugno di ferro
Corte Cassazione Civile, sezione seconda - Sentenza n. 6384/2010
Crash test speciali
Wildhaus: un terrificante crash test in zona scarico camion
Wildhaus: uno spettacolare crash test sul pericolo pedoni
Wildhaus: un drammatico crash test sui pericoli delle E-Bike
LAST: i crash test per le auto da competizione
Caroselli in auto, quando la festa si trasforma in tragedia
Trasportare i bambini in bici, qual è il sistema più sicuro?
Crash test auto cinesi, Great Wall Hover
Microcar, sono sicure come le automobili? Ecco un altro crash test
Crash test auto cinesi, Great Wall Steed
Speciale ADAC, attenzione agli animali selvatici!
ADAC ci porta dietro le quinte di un test frontale ufficiale EuroNCAP
Le auto a GPL e Metano sono sicure? Il crash test di ADAC
Gli ESC non sono tutti uguali ed EuroNCAP si adegua. Ecco il nuovo test
Sicurezza furgoni, a che punto siamo?
I primi 50 anni di IIHS, festeggiati con uno spettacolare crash test
Honda Goldwing: la prima moto con l'airbag, protegge davvero?
Animali in auto, come trasportarli in tutta sicurezza
Crash test di compatibilità all'americana. Grandi contro piccoli
Bambini ed airbag, pericolo molto spesso sottovalutato
Crash test ADAC, quando l'impatto avviene sullo spigolo
Pericolo bagagli! Ecco un crash test ADAC che lo dimostra
Conferenza stampa EuroNCAP Roma 2002
Crash Test | Beetle (Maggiolone), Golf II e Golf IV
Crash Test Compatibilità : smart contro Mercedes Classe S
Tutti i segreti del test pedoni o pedestrian test
Le Microcar sono davvero sicure? Analisi di un crash test
Crash Test Compatibilità | Volkswagen Polo contro Volkswagen Phaeton
Crash Test Compatibilità : Opel Corsa contro Mercedes Classe S
Crash test, Fiat Tipo, Ford Escort, Honda Civic, Opel Astra, Toyota Corolla, Volkswagen Golf
Speciale Citycars - Sono davvero sicure come pensiamo?
Rollover crash test | Mazda MX5, Opel Astra, VW Beetle
Rollover crash test | BMW Mini, Citroen C3, Peugeot 207
Crash test EuroNCAP a 80 km/h invece di 64 km/h
Crash test compatibilità Fiat 500 contro Audi Q7, chi vince?
DR5 crash test con protocollo EuroNCAP? Chery Tiggo
Viaggio al Centro Sicurezza Fiat di Orbassano
